I have a 67 F100 that I pulled out the 460/C-6 combo. It has a 3.25 rear diff. I put in a 300 I-6 with a 4speed out of a 85 F150. Can I just swap out the 3rd member out of a 70 F100 that has 3.70 gears. Basiclly this 3rd member has 10 teeth vice 12 which would make it a 3.90. Any advice??
So i understand you all, I can take the 10 tooth pinion gear that was matched with a 37 tooth ring gear and put in to a rear end that has a 39 tooth ring gear.
yes you can. the 3rd members bolt in the same in every 9in. you just have to make sure that the axle splines are the same. you should have 28 splines on both but you should verify that they do.
I do not believe you can. Ring and pinion gears come as matched sets. You can take one 9 inch pumpkin and put in another housing as long as you have the proper axels. Most of the early 9 inch rearends had 28 spline axels and a lot of the later ones had 31 spline axels.
Ok, so I switched out the 3rd member. Noticed a little play in it. Drove it real slow, made some clunking noise and didn't move well. Got it jacked back up and took it apart. Pieces of the ring gear teeth sheered off. Not good!! Not sure what I did wrong?? Any thoughts??
