better diesel????
Old Feb 19, 2011 | 11:00 PM
speedracer54729's Avatar
speedracer54729
better diesel????
iwas looking at rebuiloding a 7.3 aftertalking to a guy im thinking bout a 6.9 now??? is a6.9 really the better idi
Old Feb 19, 2011 | 11:18 PM
oreocreaming's Avatar
oreocreaming
if you do a search, you will see maybe 100 postings about this subject. the 85-87 6.9l is the superior motor. has all the upgrades of the block and rockers as the 7.3l but the stronger cylinder walls of the 6.9l. the 7.3l is more prone to cavitation and under heavy boost, the walls flex causing the cavitation to come though much faster.
Old Feb 19, 2011 | 11:19 PM
Phy's Avatar
Phy
The big issue with the 7.3 is the thin cylinder walls. This makes them more susceptible to cavitation. This also means that they shouldn't be bored out during a rebuild. If you have a block that just needs a honing, and doesn't have cavitation pin holes, that would be fine to build...
Old Feb 19, 2011 | 11:59 PM
Aune163rd's Avatar
Aune163rd
If you want a 6.9l motor to rebuild i have one that im giving away.
Old Feb 20, 2011 | 08:35 PM
speedracer54729
thankyou for the offer. Its funny because i livein wisconsin but work in the oil field in williston nd
topgunn
22
Oct 29, 2009 05:55 PM
drewdole
Jul 25, 2009 11:40 PM
danield
Aug 29, 2008 09:11 PM
vaman4215
May 25, 2007 10:57 AM
tired iron
15
Feb 3, 2006 03:09 AM
