Stock Timing
Old Feb 19, 2011 | 01:03 PM
underwaterboy82's Avatar
underwaterboy82
Stock Timing
was wondering what the stock timing is on a 93 50 motor. just replaced the oil pump, oil pan gasket ane all main bearings. next is the timing chain and spockets, front seal etc. so when i do this i would like to know the stock timing so i can check it afterwards. thanks jake
Old Feb 19, 2011 | 01:24 PM
lew52's Avatar
lew52
Stock is 10 deg BTDC with the spout out....Lew
Old Feb 19, 2011 | 01:44 PM
Encho's Avatar
Encho
The Southernmost Mod
But! getting your timing up to 12 - 14 will wake that engine up, this will work even better if you do a tune-up (new spark-plugs, cables, cap and rotor, meybe even a coil).
Old Feb 19, 2011 | 02:33 PM
underwaterboy82
well ill look into all those things as well. as it goes right now im gathering all the parts so i can replace the head gaskets up, the timing chain etc., serp belt, all ball joints and tie rods w/ new dual serring sebilizers. its drivng my wife crazy on how much im having to put into it this last year. although really the last 5 years i really havn't put much into it. so i guess time is due for things to fall apart, lol. thanks guys ill keep the 12-14 thing in mind when im doing it.
