I just put a pushbutton ignition in my '86. I ran a new wire from the ignition switch to the starter solenoid, and attached the wire to the "S" post on the solenoid. I was hoping that with this setup, when I pushed the start button, with the key in the ON position, that it would start. But I have to have the key turned all the way to the START position, and then press the button, and it starts. What do I need to change to make it work?
