Light on 4x4 switch?
Old Feb 19, 2011 | 09:57 AM
anjcohen's Avatar
anjcohen
Hello,
Can anyone tell me if there is a light on the 4x4 auto switch on the dash? Mine does not light up at night.
Thanks....
Old Feb 19, 2011 | 11:31 AM
jwill8957's Avatar
jwill8957
the light on the dash will ight up
Old Feb 19, 2011 | 11:38 AM
Lstanley's Avatar
Lstanley
My light for the 4x4 is located in my instrument cluster at the bottom. Not on the switch.
Old Feb 19, 2011 | 11:42 AM
PaysonPSD's Avatar
PaysonPSD
My 4X4 switch is not backlit.
Old Feb 19, 2011 | 12:30 PM
woodnthings's Avatar
woodnthings
Originally Posted by anjcohen
Hello,
Thanks....
What year is your truck? My '02 has back lighting for the switch, but sounds like the older ones may not.
Old Feb 19, 2011 | 12:53 PM
bluescrew's Avatar
bluescrew
i wondered about this too last year, yanked off the switch. yep, LED burnt out.
2001
Old Feb 19, 2011 | 01:55 PM
jberrouard's Avatar
jberrouard
My 02 has a back light. It also burnt out. I took the bulb out and went to the dealer figuring they were like dash lights and could buy one. Nope can only get it by buying a new switch which they quoted me at $50 which was cheaper than I expected.
Old Feb 19, 2011 | 02:10 PM
woodnthings
Take a look at these posts/articles. You can in fact replace the bulb in it for around $4.00.
Here is the bulb they mention
Neo - Wedge Tall LED Instrument Panel Bulbs
(About half way down the page)
FTE ESOF Bulb Thread
ESOF LED UPGRADE ARTICLE
Hope that helps you all!
Old Feb 20, 2011 | 12:30 AM
Bonanza35's Avatar
Bonanza35
Do all these 4x4 switches light up. I have never noticed it on mine. 99 thanks, Chet
Old Feb 20, 2011 | 07:43 AM
woodnthings
I am guessing not, they make subtle changes every year and that was probably one of them. Just pull your switch out (they just pop out of the dash) and see if it looks like the one in the article.
Old Feb 20, 2011 | 10:58 AM
anjcohen's Avatar
anjcohen
To answer one of the replies to my post:
I have a 2003 7.3L
I am specifically addressing the 4x4 auto switch / dial and not the 4x4 light on the dash cluster.
It seems logical there this dial switch should have a light. If so please let me know and how would I replace?
Thank you.
Old Feb 20, 2011 | 11:01 AM
anjcohen's Avatar
anjcohen
Wow! Just read your reply.................thank you!!!!!!
Old Feb 20, 2011 | 09:57 PM
big poppa's Avatar
big poppa
Mine has the backlight LED behind the actual 4x4 marking. Mines been burned out for some time now so thanks Ken, again..
Old Feb 21, 2011 | 08:36 AM
F-250 Super Duty's Avatar
F-250 Super Duty
I have an '02 and can't ever recall that switch being lit up??? Any idea what wire on the harness plug would be the light wire? I'd like to test it and see if there is in fact a light there......
Old Feb 21, 2011 | 08:44 AM
dothedew192's Avatar
dothedew192
My 02 4x4 switch didn't light up for a long time, for some reason about two months or so ago it lit up and has worked every since. Weird what the cold does to electrical. But I never mind a problem that fixes itself.
