help with the headlights
Old Feb 18, 2011 | 09:43 PM
ffmikehardy's Avatar
ffmikehardy
Cool help with the headlights
coming home tonight i went from high beams to low and the headlights shut off. all the others worked but not the head lights. got home and they came back on FTW . is the dimmer switch bad or is it the switch on the dash. please help.
Old Feb 18, 2011 | 09:53 PM
The Confederate's Avatar
The Confederate
Sounds like a jammed dimmer switch. Could be the power switch, but the way it happened... Also check the wiring, these ol' girls are awesome for deteriorated wires. Check all the connections, too.
Old Feb 18, 2011 | 10:04 PM
ranger429's Avatar
ranger429
I agree, dimmer switch. Check power at the D/S while switching from high to low and see what it reads.
Old Feb 19, 2011 | 03:52 PM
79F150400M's Avatar
79F150400M
Had That Problem...
and it was the headlight switch. Replaced dimmer switch after that just for good measure since the old one was looking pretty bad.
Old Feb 19, 2011 | 07:19 PM
ffmikehardy
well it worked great today. just my luck but got a new dimmer switch just in case it happens again. thanks guys.
