ND: Steering box help
Old Feb 18, 2011 | 05:54 PM
salf100's Avatar
salf100
ND - could you list the parts needed to rebuild the manual steering box on my 64 F100. A list of current vendors also please. Thanks a million.
Has anyone done this rebuild themselves? Is it pretty easy?
Old Feb 18, 2011 | 06:51 PM
F250GH's Avatar
F250GH
Found this by doing a search
Quote:
Originally Posted by jaymorris
Just took out my old sloppy gear box. The better gear box is draining now (looks like molasses coming out). Is there a cleaner of some type I can put in the better gear box and not ruin it? Or should I just put fresh grease in it and see what happens. Also, what type oil/grease is recommended for the gear box? I have to assume the parts truck gear box is 45 years old also. But it is very tight and smooth turning.
The gearbox uses 90 weight gear oil.
You can use a solvent like kerosene to clean out the gunk.
This is a simple gearbox to rebuild, usually all it needs is the following.
These exact same parts were also used in 1950/60's passenger cars.
2) C2AZ3552A .. Steering Shaft Bearing Race / Obsolete
ANTIQUE AUTO SUPPLY in Arlington TX has 3 = 817-275-2381.
PARTS INTERNATIONAL in Farmers Branch TX has 50 = 888-727-0418.
KINSEL L/M in Beaumont TX has 8 = 800-816-2894.
GREEN SALES CO. in Cincinnati OH has 41 - 800-543-4959.
2) C2AZ3571A .. Steering Shaft Bearing / Obsolete
PARTS INTERNATIONAL has 4.
KINSEL L/M has 4.
ANTIQUE AUTO SUPPLY has 2.
GREEN SALES CO. has 2.
1) B8A3576A .. Sector Shaft Bushing / Obsolete
ANTIQUE AUTO SUPPLY has 1.
KLIMESH AUTO SALES in Calmar IA has 1. = 563-562-3241.
LYLE'S FORD in Eagle Grove IA has 2. = 800-397-6319.
TISON MOTOR CO. in Estill SC has 1 = 803-625-2551.
1) C3AZ3581A .. Housing Gasket / Obsolete
KINSEL L/M has 8.
PARTS INTERNATIONAL has 14.
GREEN SALES CO. has 112.
1) C7OZ3591A .. Sector Shaft Seal / Obsolete
KINSEL L/M has 8.
DON SANDERSON FORD in Glendale AZ has 58 = 623-842-8762.
PARTS INTERNATIONAL has 50.
GREEN SALES CO. has 109.
__________________
Bill // Retired Ford Parts Manager // Part Number Research: 1928/2001 FoMoCo vehicles.
2011 F150 5.0L Lariat Super Crew.
Old Feb 19, 2011 | 02:34 PM
salf100's Avatar
salf100
Thanks, my searching skills arent very good! I never seem to find anything.
Old Feb 19, 2011 | 02:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The list in post #2 does not include all the necessary parts. I only listed the basics (seal/gasket/bearings/races/bushing) and it's an old list, so some of the sources may no longer have the parts.
Sometimes the basics only need to be replaced to tighten up the box.
1961/64 F100/250 2WD Steering Gearbox parts:
1) C1TZ3524A .. Steering Shaft & Worm.
ANTIQUE AUTO SUPPLY in Arlington TX has 2 = 817-275-2381.
GREEN SALES CO. in Cincinnati OH has 10 = 800-543-4959.
2) C2AZ3552A .. Steering Shaft Race.
GREEN SALES CO. has 33.
2) C2AZ3571A .. Steering Shaft Bearing.
WESLEY OBSOLETE PARTS in Liberty KY has 2 = 606-787-5293.
HASELDEN BROTHERS in Hemingway SC has 3 = 912-367-2466.
MILLER OBSOLETE PARTS in Vestal NY has 4 = 607-722-5371.
KINSEL L/M in Beaumont TX has 5 = 800-816-2894.
PARTS INTERNATIONAL has 5.
1) C3TZ3575G .. Sector Shaft.
No FoMoCo Dealer or obsolete parts vendor has any.
1) B8A3576A .. Sector Shaft Bushing.
PARTS INTERNATIONAL has 1.
KINSEL L/M has 1.
EARL FLOYD FORD in Carrollton KY has 1 = 800-732-2037.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
SAPP FORD in Baxley GA has 1 = 912-367-2466.
DICKERSON MOTOR CO. in York SC has 1 = 803-684-4225.
HASELDEN BROTHERS has 1.
TISON MOTOR CO. in Estill SC has 2 = 803-625-2551.
1) C3AZ3581A .. Gearbox Housing Gasket.
GREEN SALES CO. has 439.
1) C7OZ3591A .. Gearbox Housing Seal.
GREEN SALES CO. has 142.
ghettoshelf
Nov 10, 2012 07:51 AM
fnzen
Mar 22, 2012 01:22 PM
UncSam
Sep 22, 2010 11:31 PM
Mototron
Oct 19, 2002 07:55 AM
Forddrof
Aug 11, 2002 07:52 AM
