20 min warm-up time.
Old Feb 18, 2011 | 09:48 AM
amsett's Avatar
amsett
Hello everyone, my 97 F250 takes about 15-20 minutes for the truck to warm up everytime. Is there a sensor I need to replace or the thermostat?
Old Feb 18, 2011 | 10:28 AM
RRranch's Avatar
RRranch
That's not bad. Unless it's over 80 out all of ours take about that long. If it's below zero we just wear coats. You can get a cheap laser thermometer at ace hardware and check your thermostat outlet temp after it does warm up. If it's about 195 to 200 then the thermostat is fine.
Old Feb 18, 2011 | 12:29 PM
JamesHajek's Avatar
JamesHajek
Is that just idling in your driveway? You have to drive the truck to warm it up. That's just the nature of the beast.
Old Feb 18, 2011 | 12:38 PM
jtexfisher's Avatar
jtexfisher
I've never had the patience to wait for mine to warm up idling. Even when it's fairly cool out (like 20's) I'll give it 2 or 3 mins to warm up before driving. Still it takes about 6 to 10 miles on the highway before the heat kinda gets a bit warm and the temp gauge starts moving. After about 15 miles it's mostly up to temp, and the heater will chase you out if it's on high.
