temperature warnings?
Old Feb 18, 2011 | 01:34 AM
7.3bo-ti-etr's Avatar
7.3bo-ti-etr
So got my Gauges in and just seeing where I stand as far as temps. Temps are taken driving at 70 MPH driving for 30 minutes. Oil 225-230, trans 120, fuel 70, pryo 500-600. Also the pryo is in the down pipe 6" after the Turbo what is the Max temps I should watch out for so I don't do any damage.
Old Feb 18, 2011 | 02:00 AM
timmyboy76's Avatar
timmyboy76
You go with the Glowshhift? If so, with the fuel pressure gauge, did you order the adaptor from them also, to mount the sendor?
As for the pyro reading, my numbers are the same, but mines' located pre-turbo, if that means anything
Old Feb 18, 2011 | 05:31 AM
just another truck's Avatar
just another truck
What, no boost?
Your numbers look good!!!
Old Feb 18, 2011 | 06:45 AM
bcaughhorn's Avatar
bcaughhorn
my pyro is pre turbo. to monitor whats going in not coming out. my trans temp is the same. dont have a fuel yet
Old Feb 18, 2011 | 06:49 AM
Ponyboychris's Avatar
Ponyboychris
Post turbo EGT monitoring will be different than just about all of us. It's more common to mount the pyro on the up-pipe on the driver's side before the exhaust hits the turbo (Pre-turbo). Your temps will be lower when comparing them. Just an FYI
Old Feb 18, 2011 | 07:42 AM
7.3bo-ti-etr
I do have boost just not hooked up yet. So what would be the Max temp on a post Turbo set up also warning temp on oil. Thanks
Old Feb 18, 2011 | 09:45 AM
stroken7.3's Avatar
stroken7.3
Your oil temp should be about 10* hotter than water temp, mine usually runs 5* to 7* hotter. And where you have your pyro keep your max egts to 1100*. Hope that helps a little.
Old Feb 18, 2011 | 07:59 PM
7.3bo-ti-etr
Well then it looks like ill need a water temp gauge then. So if the post egts get to a 1000 I need to back off or shut her down right?
Old Feb 18, 2011 | 08:54 PM
JOHN2001's Avatar
JOHN2001
I have a pre turbo egt probe and at 70 mpg my egts are usually around 600-700, I read a forum some where here that explained what you shoud see pre and post turbo egt, i cannot find it. From what your egts are and what mine are there seems to be between 100-200* difference at 70 mph
Old Feb 19, 2011 | 12:58 AM
USAF CCM's Avatar
USAF CCM
The best reason to have your EGT probe pre-turbo is to watch the temps at their earliest point.....it's not the turbo you're protecting per se, it's the PISTONS!
Old Feb 19, 2011 | 08:12 PM
joeyd61's Avatar
joeyd61
The pyro really need to be pre turbo.I ran mine post for a while and moved it to pre and have seen 300-400 deg difference..i also believe you can buy a post turbo pyro and it will go to yellow (caution) at 900 f.... all else sounds fine to me
