Subford, I have a similar problem with a 1986 F150 XLT 5.0 efi with dual tanks. No power to any pumps. If I jump out my test connector the truck runs fine. Any idea where to go next?
If you are grounding pin #6 of the self-test connector and it runs and will not run when it is not grounded then either the wire is open from the self-test connector to the computer, the computers pin #22 is pushed out or wire the wire is broken off of it or you have a bad EEC Computer.
Im having the same problem with my 88. Its driving me nuts. I ground out the fuel pump relay which i believe is pin 6 the fuel pump goes on and WHEN it starts itll run but eventually stall. Im going to try and jump 2 and 6 tomorrow morning sometime. As soon as i get it running im selling. !!!!
