tps question
Old Feb 17, 2011 | 08:35 AM
cpettymore7777's Avatar
cpettymore7777
tps question
on my 95 f250 351w i sometimes have a high idle and once in awhile the throttle seems goofy. so im thinking its not the iac. its the tps. is there any special set up you need to do to replace it or just remove and install. and if anyone knows what type of screws hold it in would help too. with half my leg being metal its a project trying to get in and out of the engine compartment. thanks.
Old Feb 17, 2011 | 09:16 AM
Lazy K's Avatar
Lazy K
Ford Fuel Injection » Throttle Position Sensor (TPS) Here is a link on how to test the old one before you remove it.
Old Feb 17, 2011 | 09:46 AM
subford's Avatar
subford
Button head Phillips-head ("crosshead") screws (two).
I use a small pair of vice grips to break them loose or you will round them out.
Old Feb 17, 2011 | 02:13 PM
cpettymore7777
thanks for the reply. so there is no set up i have to do on the new one?
Old Feb 17, 2011 | 04:26 PM
subford's Avatar
subford
It should be plug and play.
