grille change
Old Feb 16, 2011 | 12:28 PM
jbarefoot's Avatar
jbarefoot
grille change
Are the 73-79 grilles interchangeable? Can I put an older grille on my 79 dent?
Old Feb 16, 2011 | 12:52 PM
starwriter's Avatar
starwriter
1973-79 Grill Compatibility
The 1973-77 grills interchange no problem. The radiator core support is different for the 1978-79 grills. Basically the headlights don't line up correctly between the 73-77 and 78-79. You will need to change out the radiator core support or do some fabrication to get an older grill to fit on a newer truck or vice versa. It has been done and I'm sure others can chime in with the details for how to do it. From my understanding it all unbolts but it is a bit of work. I have replaced the front dog house on my truck and that took me a good Saturdays worth of work. While you are doing this it might not be a bad idea to replace the front body bushings and everything else rubber you will be removing to take off the support.
Old Feb 16, 2011 | 01:36 PM
akforceten's Avatar
akforceten
When I changed over my grille on my 78 bronco the grille was bolt in . as far as the headlight goes I got a set from the grille I was using. The only modification was drilling new holes to bolt the older headlight bucket to the 78 radiator core support .
Old Feb 16, 2011 | 02:27 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
A 73-77 grill shell will work in a 78/79 you just need to get the headlight buckets/mount hdwr that match what ever grill year you are using. As far as I know no need to change the whole radiator core support.
When you get the grill shell and buckets of what ever truck, I would take some measurements off that old core support to know where the mounting holes need to be added or changed.
Also know that your park light wiring will need to be long enough to move from the bottom to the top of the grill.
Here is a paint scheme on each year that's a little different.
Old Feb 16, 2011 | 03:26 PM
POPAJON's Avatar
POPAJON
X2 on that 77&79. I changed my 77 to the 78 grill and the only parts I needed were the ones that you just posted.
Old Feb 16, 2011 | 06:44 PM
first today's Avatar
first today
When the weather is better, I will finish putting a 1969 grill on my 79. It is all bolt on in the original holes so far.
Old Feb 16, 2011 | 06:53 PM
79 f350ts's Avatar
79 f350ts
that should be interesting, post some pictures when your done. not sure ive ever seen a bump grill on a dent
Old Feb 16, 2011 | 07:20 PM
first today
That is the idea. I want it a little different. I also want it to look older than it is.
Old Feb 17, 2011 | 05:00 AM
jbarefoot's Avatar
jbarefoot
Thanks for all the advice, this will make things much easier.
blk450er
18
Jun 6, 2017 04:50 PM
Damifiknow
Ford Truck Parts for Sale
Sep 6, 2016 01:56 PM
ironman540
WTB - Parts & other
19
Nov 6, 2012 07:33 AM
mad_jack
Feb 10, 2009 05:38 PM
DCP
31
Dec 20, 2008 11:30 PM
