Originally posted by WKMOTZU Does anyone know of a good source for 20 inch wheels for Excursions??
WKMOTZU,
I think I just read your other post about pulling a 10,500 lb trailer. I think you should do some research about those rubber band tires and how much load they can carry!!! I know most eXcursions weigh in excess of 7800 lbs, that plus the almost 11,000 lbs of a trailer is a lot of weight for rubber band tires. You will need a good Load range "D" or "E" tire!
Good Luck
I agree , i doubt you would be able to safely pull any type of trailer with anything over a 17'' wheel in my opinion. I see SUV's with "rubber bands" for <a href="http://service.bfast.com/bfast/click?bfmid=37919709&siteid=39251846">tires </a>all the time in Chicago pulled over on the side of the road becaue a pothole just ate their tire, and messed up their "Bling-Bling" wheels
Check out this site. They have 19.5" RV & commercial tires on rims designed to fit F250's & F350's. The don't list the Excursion, but I would think that they would fit. The rated weight limits are at or way above the OEM tires that came on your Ex.
