O2 sensor
Old Dec 28, 2002 | 08:12 PM
CrazyFordMan's Avatar
CrazyFordMan
O2 sensor
How much power will i lose if my O2 sensor is gone?
1992 F250 r/c l/b 4X4 351 ZF5spd 33" BFG Allterrains clarion CD MTX 6500D amp pushin 2 12" 6000 series subs
Old Dec 29, 2002 | 11:15 AM
CrazyFordMan
O2 sensor
what should happen if i unplug it when the truck is running?
Old Dec 30, 2002 | 02:09 AM
CrazyFordMan
O2 sensor
Anyone???
Old Dec 30, 2002 | 06:55 AM
EPNCSU2006's Avatar
EPNCSU2006
O2 sensor
The computer would run in a base mode, causing performance and mileage to suffer.
Old Dec 30, 2002 | 04:48 PM
Hit Man X's Avatar
Hit Man X
O2 sensor
It will run like crap, throw a code too. Why are you asking?
Old Dec 30, 2002 | 07:10 PM
geoaigel's Avatar
geoaigel
O2 sensor
You don't want to unplug your O2 sensor, period. It will screw things up. It is part of the ECU sensing system. It isn't one of the *bad* emission control things that will make your truck *slower*. Cheers,
George
Old Dec 31, 2002 | 11:27 AM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
O2 sensor
Anyone know what the life expectancy of an O2 sensor is? Mine is 13 years old and over 120,000 miles on it. Should i change it?
Old Dec 31, 2002 | 02:19 PM
plugugly's Avatar
plugugly
O2 sensor
Old Dec 31, 2002 | 09:24 PM
MustangGT221's Avatar
MustangGT221
O2 sensor
Yes you should change it. If you unplug it it wont run bad, runs ok I didn't notice muhc of a change but it makes your engine run really rich.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Dec 31, 2002 | 09:31 PM
jrs_big_ford_f150
O2 sensor
Thanks MustangGT221, I will change it soon. Payday is coming up.
Old Jan 1, 2003 | 12:13 AM
CurtisF250's Avatar
CurtisF250
O2 sensor
Okay I know my O2 is bad and I was told that I need to replae the left one now where is it?????
I have a 96 F-250 with a 351 Windsor.
Old Jan 3, 2003 | 10:20 PM
Hit Man X's Avatar
Hit Man X
O2 sensor
Well you probably have 2 maybe 3 since your truck is OBD II. Replace them all if you can afford it. They are about $50 each. They are easy to spot...they have 3-4 wires running to a sensor that is about 3-4" long in your exhaust system.
I went with Bosch for mine.
Good luck
