CPS Again ??
Old Feb 14, 2011 | 08:55 PM
AngeliasDad's Avatar
AngeliasDad
CPS Again ??
So those classic CPS symptoms are happening again , I thought those grey ones where suppose to be better . So should I replace it or let Ford do it this time ..... Grrrrrr stupid CPS ......
Old Feb 14, 2011 | 09:32 PM
woodnthings's Avatar
woodnthings
What symptoms are you having? I see a lot of people change them out when they are not the problem.
Old Feb 14, 2011 | 09:44 PM
jcrammell's Avatar
jcrammell
I had an old black one that I had gotten off of ebay just go bad on me. It would just die for no reason. Once while taking off from a light. At least she started back up and went but what a pain. Put in a brand spanky new one and no problems so far.
Old Feb 14, 2011 | 10:10 PM
AngeliasDad
Well it runs great for a while then start to get this little hiccup , it starts to get progressively worse , loss of power , and some times dies when I'm at a stop .
Old Feb 14, 2011 | 10:25 PM
woodnthings
I would investigate a loose UVCH based on that bit of information. Also wouldn't hurt to check fuel pressure. How old is the oil you are running?
Old Feb 14, 2011 | 10:32 PM
AngeliasDad
UVCH ? hmmm the oil is over due cause I thought it might be that too . When it started acting up I pulled over and checked the oil and I'm ashamed to say it was realy low so I put a gallon in to bring up the levels , but it still ran crap for quite a while and then stopped and ran fine ..on my way home from work it ran great 3/4 of the way home then started acting up again ...
Old Feb 14, 2011 | 10:41 PM
littlegreenblur31's Avatar
littlegreenblur31
I had the same problem. With my 02 woodsnthing helped me diagnose the problem it was a loose uvch. We pulled the valve cover and it had almost came completely off. I had the same symptoms it would come and go till it got to the piont where it was a constant.thanks again ken
Old Feb 14, 2011 | 11:31 PM
jcrammell's Avatar
jcrammell
Never thought about the UVCH. I have stopped driving the truck due to company car. Will have to take a look at that just to make sure that isn't the problem. Might as well tighten every thing up in there while I'm in there. Sounds like a project for this weekend maybe. Thanks guys'
Old Feb 14, 2011 | 11:38 PM
littlegreenblur31
When I did mine it took about 3 hours. Think about replacing the harness just for gp napa has the harness for about $26 part number 600 2967
Old Feb 15, 2011 | 07:37 AM
woodnthings
If your oil is over due, you may consider changing it first. Dirty oil has caused many people issues with rough running and intermittent issues.
Old Feb 15, 2011 | 10:40 PM
jcrammell's Avatar
jcrammell
Ken not sure if you were talking to me or not, but my oil never goes over the time it is due by more than a couple hundred miles if that. I change my oil religiously. Kinda **** that way.
Old Feb 15, 2011 | 10:56 PM
woodnthings
No. That was in reference to the OP statement about being overdue and low quantity.
