Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
- How to Replace Spark Plug Wires
Step by step instructions for do-it-yourself repairs
How to replace your 4.6L & 5.4L spark plugs
#558
Thanks Racer. Back again though......the whistle that stopped when I replaced my IAC is back, and my idle is a bit rougher now. It sounds just like before replacement. It is a Motorcraft part. Is it possible that dirt migrated into the new part? Another thread I read talked about IAC reset? Any ideas before I remove and clean? Note: whistle starts just above idle, and take off can be prone to lunging like before, but not as pronounced.
#560
#561
I've yet to do this...have plugs ready.
I've yet to change my plugs on my 2000, 5.4 V8. Let me clarify - I was going to do this awhile back, but ran into time constraints before I really got started. I took a couple of plugs out, just to check them (I was not original owner of truck), and could see they were not the original plugs (they were Bosch). I just left them in then, as the truck was running fine, and I figured someone had already changed them once.
I'm now at 190000kms (here in Canada), and I've got some Motorcraft plugs ready to go.
Is the consensus, that I should probably replace the coil boots, while I'm doing this? I believe my coils are fine (original), but I'm guessing the boots probably have seen their age.
My understanding, is that we *don't* use anti-seize on the plug threads, and we torque to 28, right?
#562
Finally did mine yesterday. Autolite APP103 double plats, 4 hours, the usual problem at #7 getting to the COP bolt. The old ones had 103,000 miles, and the gap on them was at 0.060 to 0.064. Not too bad, but I'll be happy not to tackle this again for about 10 years.
I printed out Racerguy's notes way back when and stuffed them in my Chilton's manual. This thread was only 3 pages then.
#563
Original plugs - 125k miles
Just started changing the plugs out of my 2003 SCrew 4.6L. Picture below are #1 thru #4. #2 was barely hand tight, and looks like it was getting hotter than the rest, maybe some exhaust leakage? Not my idea of fun... blind re-install on #4 had me holding my breath. Will be tackling driver's side later in the week.
#565
1998 E-150 spark plug/cop failure? triton 5.4
hey i'm new to the forum,1st post. my van has been running good for the past year i've owned it. all of a sudden it starts to miss.i was 200 miles from home getting a IHC travellal to take home to part out. i got home an took it to advance auto parts to have them test my motor to see which cylinder was mis-firing. everytime they hooked up the " OCD " hand held tester,it would shut off the tester. after 3 other parts store stops, 2 at advance, & 2 at o'reilly's.no body could get it to come up with a code. so this will be my 1st time getting into a 5.4 triton motor. this van has 164,000 miles on it and is a dream to drive and tow with.i checked the wires going to the hand held tester plug in,and they all looked good,but were loose in the connector thats screwed just under the dash part under steering column. i've been doing some reading,an it looks like the easiest way to perform this check is to,unhook each COP 1 at a time to find the " BAD 1 "... TIA for any help or info---jeff
#566
#567
Check for blown fuse#23-20amp in I/P fuse panel. The data link connector also shares the same fuse for the cigar lighter.
#569
thanks alot Lime1GT,that was it.# 23 fuse was blown,oreilly's hooked up their tester an it said # 6 cyl., mis-firing---Circuit G ground,primary. so now,i'm gonna get a can of sea-foem an dump in the gas,drive a few days., ( will spray kroil around the spark plug base,( kinda hard to see,but will spray enuff to hopefully get it ) wet..then pull the doghouse off again,an change out the plug 1st.then if i have to,i'll change coil. i can get the coil " COP " at rock auto for $15,$3.95 for boot,unless you think they are not good enuff. parts store wants $41,w/boot...thx-jeff "98-econoline van,5.4-- can get right to most of them thru inside of van,other 1/2 thru front under the hood. jeff
#570
Good for you. I would recommend changing a plug boot with each plug if the boot is old. They deform after years of heat and probably will not seal the plug to boot or plug hole to boot off well from water. Also smear a dab of dielectric grease just inside the boot to about 1/4" deep to help prevent water intruding between boot and plug porcelain which can cause a misfire. It will also assist in removing the boot at next change.
