Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
- How to Replace Spark Plug Wires
Step by step instructions for do-it-yourself repairs
How to replace your 4.6L & 5.4L spark plugs
#497
I wrote this out for someone else but I figured I'd post it here too. The 4.6L with plug wires is a bit different but similar.
If anyone has any comments or other ideas on how to do the job post them here and maybe we can combine them all and make one good tech article.
It seems that most people on here recommend Motorcraft spark plugs. That is all I will use too. Some people on here have had good luck with other brands and some people have had bad luck. Gimmick type spark plugs seem to usually be a waste of money. Something to remember is that a spark can only jump one gap at a time so having 2, 3, or 4 electrodes doesnt make much sense to me.
Autolite and Motorcraft spark plugs are not the same. The same company that makes Fram filters also makes Autolite plugs. I wont use Fram filters and I wont use Autolite plugs. That is just my opinion though.
Motorcraft plugs can be bought at your local dealer and the prices at the dealer wont always be more than at other places. Ford has been keeping the prices on their common parts in line with the aftermarket in most cases. Apparently most Autozones also carry Motorcraft spark plugs.
Remember just because I'm a moderator here doesn't mean I know everything so feel free to comment
Click on the blue words to see pictures.
I've replaced plugs on quite a few 5.4s now and once you've done a set they really arent as bad as they look.
Contrary to what some people will tell you, you dont have to remove the fuel rails. The Coil On Plug (COP) assemblies will come out past the fuel rail.
I take an old piece of seat foam and put it on top of the rad support to the engine to allow me to lay on it without hurting my tummy
It makes the job way less painful.
Start by removing the cover over the throttle body...the black plastic cover that says 5.4 on it. There are 3 10mm head bolts that hold it on. Next remove the air intake tube from the throttle body to the air filter housing. You loosen the hose clamps at either end of it, disconnect the connector on the IAT (about half way up the air intake hose), the pull out the small hoses that go into the air intake tube near the throttle body.
Next remove the brace from the power steering reservoir to thermostat housing. There are three 8mm or 5/16" head screws that hold it on.
Now you should be able to see the COPs
To remove the COPs you can use a 7mm or 9/32" wrench or nutdriver or socket, extension and ratchet or all of the above.
If you turn the fuel injectors to the side it will give you more room to work with the COPs. Unplug the connector on each COP by pressing the tab in and pulling on the connector. After you're done that just twist and pull the COPs out. A couple of the COPs on the driver's side and #4 on the passenger's side are a bit hard to get at but with some patience they will come out.
After you've removed the COPs take a blow gun and blow out the spark plug holes. Dont be surprised if there is rust and junk in them.
Next you can actually remove the plugs. Use a combination of extensions, swivels (universal joints), sockets and ratchets to get at them. Whatever works best for you is good
On the harder ones to get at I usually use a socket with a 4" extension, then a swivel, then a long extension, then the ratchet.
The plugs are way down in the holes which is why I use the extension then the swivel. The swivel makes it easier to clear the firewall etc.
Set the gap on the new plugs to whatever it says on your emissions decal on the rad support....usually .052-.056".
Apply a small amount of anti-seize to the threads only on the spark plug.
You can use a piece of vacuum hose or fuel hose over the end of the plug to get it started in the hole. Carefully start the plugs in their holes. If you can't get them most of the way in by hand with the hose take a look and see why not. Crossthreaded plug threads are no fun
The plugs are to be tightened to 13 lb-ft. which is just hand tight with a short ratchet.
Don't overtighten them! The threads in the aluminum heads have enough problems as it is.
After that just put everything back together in reverse order.
Apply some dielectric grease to the plug boots as well to help seal them.
I've done enough of these that I can replace the plugs in approximately 45 minutes but don't be surprised if the first time you do it it takes a few hours.
#498
Welcome to the forum menerene1
Nope I'm not in Oregon. I'm in BC.
I really have never had anything to do with aftermarket coils but lots of people use them and it seems that they work as well as the Ford ones.
If you follow the tips here you should be fine changing them yourself. If you have any questions about the procedure there are lots of guys here that can help.
Good luck with it.
Good luck with it.
#505
Just grab the injector at the harness and spin it around until its out of the way. You dont need to do anything to the fuel rail. If you have the proper extensions and swivels you shouldnt have any problems, the cop bolt on I think the 3rd one back on the drivers side is a little hard to get to.
#507
This is probably the greatest single thread advancing the cause of the Ford owner since Henry first posted "I got an idea about how to build 'em faster".
#508
I replaced the number four coil, boot and plug today after work. I have to say thanks to everyone for the great information that really helped me get this done relatively quickly and successfully. I took some pictures as I went along. I have a 2001 F250 with the 5.4.
The 1-4 cylinder bank before starting
http://theskypainters.com/pictures/S...y/IMAG0142.jpg
Light shining back where the number 4 coil is
http://theskypainters.com/pictures/S...y/IMAG0146.jpg
PCV disconnected and moved and all injector and coil connectors unplugged
http://theskypainters.com/pictures/S...y/IMAG0147.jpg
I removed a vacuum controller from the three studs on the left center and moved the bracket holding the controller out of the way. Not a great picture.
http://theskypainters.com/pictures/S...y/IMAG0148.jpg
The boot after removal
http://theskypainters.com/pictures/S...y/IMAG0149.jpg
The bad boot and coil assembly
http://theskypainters.com/pictures/S...y/IMAG0150.jpg
The bottom of the boot, cracked worn and no damn good
http://theskypainters.com/pictures/S...y/IMAG0151.jpg
The bad plug
http://theskypainters.com/pictures/S...y/IMAG0154.jpg
The new coil installed
http://theskypainters.com/pictures/S...y/IMAG0156.jpg
I used a Motorcraft Iridium plug that looked identical to the OEM plug, but Auto Zone only had a Duralast Ignition Coil not the OEM Motorcraft model. I disconnected the battery so the codes would clear while doing the replacement. My truck was running horribly and I got running lean codes and cylinder number four missing. The idiot light has not come back on yet and the truck is running MUCH smoother. It was particularly bad when lugging the engine at low RPM while driving. Seems to have cleared up entirely. I cleaned the MAF sensor yesterday, hopefully this takes care of the running lean problem. Time will tell, but I can drive to work now (20 miles) without worrying about badly damaging my vehicle.
The bad plug
#509
Different plugs
I noticed you said you went to an Iridium plug. Can you let us know how it holds up? I ask this because I see some plugs don't work as well as the stock ones do. I took a chance and switched to E3 plugs this time. It hasn't been that many miles so far but I'm very surprised how well they work. Chime in guys and let us know how well a non stock plug is working.
#510
