need help
Old Feb 14, 2011 | 05:00 PM
cwboyoutlw's Avatar
cwboyoutlw
need help
i have a '96 f150 with a v6 and manual the problem i am having is when i put it 5th gear it pops out when i push on the gas and stays in when i take my foot off of it unless i hold it in gear with a lot of pressure on the stick but even then it tries to pop out but goes right back in. what do yall think the problem could be?
Old Feb 14, 2011 | 05:17 PM
Slip ford man's Avatar
Slip ford man
The shift linage should be adjustable. I would try that first, adjust the rod throw a little at a time. Count how many turns you do, so that you can go back there. Make sure that you are on the right rod.
Old Feb 14, 2011 | 06:20 PM
cwboyoutlw's Avatar
cwboyoutlw
is that located inside the trans because i know on the older ones it is on the outside of the trans and where would it be located at?
tonepatron
Mar 17, 2014 06:59 AM
mstiles19
Feb 8, 2014 10:09 AM
riverguideguy
17
Nov 30, 2013 01:38 PM
riverguideguy
21
Mar 4, 2013 07:07 PM
007truck
Jun 13, 2001 07:34 PM
