side projects. Whatcha been working on?
#123
#125
#126
In case Jack's file doesn't come through right you can get the uninstall tool here too:
How to uninstall or reinstall supported McAfee consumer products using the McAfee Consumer Products Removal tool (MCPR*****)
Comes with instructions to make it purdy easy. I've done a bunch of McAffee uninstalls and the tools works everytime.
#127
#128
#129
#130
#131
Got suspension stuff done on the Bullitt over the weekend. Clint actually got the car on jackstands and had the rear brakes, shock, and springs done Friday night. Chad came over on Saturday and helped us with the front. Test fit the new wheels, then got it all buttoned up and off the jackstands. Now I've got to jack it back up and grease ball joints and install the cotter keys.
#132
#133
this morning, I went to go give plasma, and then we went to look at houses, we visited 4 houses today, and are scheduled to look at two more tomorrow. The realitor came to our house, gave us an idea of what we should ask for ours, pointed out some things we need to fix on ours, and gave us some ideas on things we need to move around and such. They pointed out our hallway opening, (it used to be a attic fan) I had put in styrofoam up there, with a blanket on top of that, then thick plastic on top of that.
Well, that had a bunch of mold growing in it. the styrofoam was turning colors. The problem was the plastic in the attic over the top, the moisture couldn't escape, my bad... In fact the plastic was holding nearly a cup and a half of moisture in it.
I pulled everything out, cleaned the mold with clorox and threw everything else out that was effected. I picked up some new plywood, paint, insulation, and foam seal, painted the wood, mounted it all up, and cleaned up. We have a huge list of things to do, but Julie thinks we can do it. It just makes me tired thinking about it.
#135
