side projects. Whatcha been working on?
#724
#727
#730
#732
Its done, it was 89 in the house when I got home today after work. I came home earlier to try to put it together but I ran into a few small problems.The heater motor I took out was a 4 speed, but this new one is a three speed. I had to figure out how to wire it differently. Its running now and its dropped down to 84, and already starting to feel better. must take a lot of time to cool down a house this size, because its been running about an hour and only dropped 5 degrees. Its one of those high efficiency units, so I am thinking it may take multiple cycles of the air to cool it down good. That or we have a new issue.
#733
Well, it finally cooled down in the house, but I am sure it helps that it cooled down more outside then inside. I had given the A/C a break, because it had been running for 5 hours, so I turned the A/C up to 75. Then just before going to bed I set it to 73, typically I like to set it at 71 at night. It was 64 out this morning, and I still heard the A/C running. I am guessing the items in the house that heated up, were still emitting heat from them as the house cooled off.
#735
Good work! Your story reminds me of when the main fan motor died at our old place. It was well over 90 inside the house for a couple of days since I had to search all over the place for a replacement. Didn't help that the A\C was originally installed the year I was born, kinda hard to find parts when the system is that old
