side projects. Whatcha been working on?
  #721
Old 08-23-2018, 11:11 AM
Garden Spyder's Avatar
Garden Spyder
Garden Spyder is offline
Nice! then your truck should be fine.
  #722
Old 08-23-2018, 12:46 PM
82'Stepside's Avatar
82'Stepside
82'Stepside is offline
Sounds awesome so far, can't wait to check it out in person sometime
  #723
Old 09-10-2018, 08:01 AM
Flip4ford's Avatar
Flip4ford
Flip4ford is offline
No on call this weekend I guess I am going to go to Beloit/jewell and work on the frame for tent camper
  #724
Old 09-19-2018, 08:20 AM
Flip4ford's Avatar
Flip4ford
Found this yesterday-- luckily I got the door open or I would have to drill this ATM --- ugh Lucky lucky lucky- The bolt is a mounting bolt for the lock fell out from years of use.
  #725
Old 09-19-2018, 08:41 AM
Garden Spyder
Wow!! that was luck!!
  #726
Old 09-19-2018, 08:54 AM
Flip4ford's Avatar
Flip4ford
No doubt!!!!!!!
  #727
Old 09-19-2018, 12:49 PM
husker's Avatar
husker
husker is offline
Need a little loctight.
  #728
Old 09-19-2018, 01:26 PM
Garden Spyder
Some of those screws come with the Loctite already installed, but apparently this one didn't.
  #729
Old 09-19-2018, 06:50 PM
Flip4ford's Avatar
Flip4ford
Yeah this was before they did the loctite thing-- it is now though :-)
  #730
Old 09-20-2018, 08:46 AM
Garden Spyder
I will probably take part of the day off today to go home and put a new motor in the A/C unit for the squirrel cage fan. It's supposed to get pretty warm today and I don't want the kids or Julie to suffer too much.
  #731
Old 09-20-2018, 05:48 PM
Flip4ford's Avatar
Flip4ford
oh I hate hvac work as much as you hate plumbing
  #732
Old 09-20-2018, 06:23 PM
Garden Spyder
Its done, it was 89 in the house when I got home today after work. I came home earlier to try to put it together but I ran into a few small problems.The heater motor I took out was a 4 speed, but this new one is a three speed. I had to figure out how to wire it differently. Its running now and its dropped down to 84, and already starting to feel better. must take a lot of time to cool down a house this size, because its been running about an hour and only dropped 5 degrees. Its one of those high efficiency units, so I am thinking it may take multiple cycles of the air to cool it down good. That or we have a new issue.
  #733
Old 09-21-2018, 07:51 AM
Garden Spyder
Well, it finally cooled down in the house, but I am sure it helps that it cooled down more outside then inside. I had given the A/C a break, because it had been running for 5 hours, so I turned the A/C up to 75. Then just before going to bed I set it to 73, typically I like to set it at 71 at night. It was 64 out this morning, and I still heard the A/C running. I am guessing the items in the house that heated up, were still emitting heat from them as the house cooled off.
  #734
Old 09-21-2018, 03:35 PM
Flip4ford's Avatar
Flip4ford
Well its good you got it fixed :-)
  #735
Old 09-21-2018, 04:12 PM
82'Stepside
Good work! Your story reminds me of when the main fan motor died at our old place. It was well over 90 inside the house for a couple of days since I had to search all over the place for a replacement. Didn't help that the A\C was originally installed the year I was born, kinda hard to find parts when the system is that old
Quick Reply: side projects. Whatcha been working on?
