i must say it is not a good feeling when you hear a POP then you loose power- i drove around a little - black smoke rolling out - heard turbo whine - still thought turbo snapped a shaft- had been working on replacing back pressure sensor so had intercooler tube off - well let's say when you suck just air - no power- put back on - tighten all clamps - back to normal
cleaning back pressure tube and change of back pressure sensor made a big diff -
That thing can come off hard enough to dent your hood! I had a little problem with mine until I sprayed it with hairspray and put it together quick. That blue rubber is slick.
I've blown it off three times now, and it scares the crap out of me every time. First time it happened I almost started crying - I was sure I'd blown the engine or something. I always carry the wrenches around with me to put it back on for a few weeks after I've worked on it.
what started it all is that i keep getting intermittent battery light - sometimes stays on then goes out - sometimes all the time - sometimes never
well the serpentene belt looked old - shroud was fun to get loose-so i went the cheaper route- with just belt but i cleaned tube and changed back pressure sensor while i was there - i know no rythm or reason
i did think it would help with the 5th gear shift and so jerking at low rpm - like 1700 - kicks into 5th - like to high of gear - even with all of above still have intermittent bat light and like slippage in 5th - just something you feel in seat not steering
the altnerator may have a loose internal something
