whats it worth?
Old Feb 13, 2011 | 01:00 AM
1980302windsor's Avatar
1980302windsor
whats it worth?
It is in the shop right now to troubleshoot an electrical issue, then its all good. Looking to upgrade to a 4X4. What should I ask for the 1980 F-150 described below: Thanks folks!
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]>******** classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui>*********> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> 175,000 Miles
V8 5.0L 302 (New 302 Short Block Bored + .030 in 1994)
Brown w/ original color matched topper (no leaks)
Some Rust à Minimal for being 31 years old. Some above rear wheel wells.
2WD Automatic 3 speed transmission
Dual Exhaust
Edelbrock Performance Intake Manifold
Edelbrock 4BL Performance series carburetor
Edelbrock 14” Round Hi-Flow air Cleaner
Flamethrower 2 Ignition Coil
Dual Gas tank (Rear tank replaced 2003-2004)
New Parts since September 2010:
Cooper Discoverer ATR 50,000 mile tires (less than 500 miles wear)
Spark Plugs/wireset
Distributor Cap/Rotor
Battery (Exide 60 Month)
Starter
Starter Solenoid
Alternator
Voltage Regulator
**Interior is in great shape. No ripped or faded fabric/vinyl. Dash vinyl is a bit cracked. Aftermarket Sony Stereo. Gear selector gauge does not work, but everything else does. Drives very well.
Old Feb 13, 2011 | 01:17 AM
Anafiel's Avatar
Anafiel
Where are you and the truck located? You might want to update your profile so others can tell where you are.
Old Feb 13, 2011 | 01:33 AM
1980302windsor
my bad. East Central, IL
Old Feb 13, 2011 | 02:24 AM
glovemeister's Avatar
glovemeister
$2500 tops.
Old Feb 13, 2011 | 04:34 PM
FordNFishinLover's Avatar
FordNFishinLover
Mind if i ask where in central illinois you live? Reason i ask is because i to am in central illinois.
Im located in the mattoon, charleston area.
I agree on the 2500 tops. Maybe 2000. Helps if you have a picture.
Old Feb 13, 2011 | 06:51 PM
1980302windsor
Paxton...north of chambana.
