Hello, Have an issue with my 2005 F350 SBCC 4x4 Srw. today the climate controls just stopped working. No lights nothing. Dead, like I will be if my wife has to ride in the truck with no heat.
Opened the fuse box and checked all the appropriate fuses. is there something else i am missing.
I did notice the the climate controls are on the same fuse as the tow haul switch. i pulled the fuse and checked it and it is good. put it back in and the tow haul light works (not sure if that is the what the fuse is controlling) but the climate control console is dead.
Are there any other connections that might have worked loose and is there an easy way to check. I am in Michigan and even though we are in a little heat wave today (30) it is suppose to get cold again tonight.
I have the same problem every once in a while with my '06 KR F350. It has only happened about half dozen times, but my fix is to turn on the parking lights. I haven't figured out why it fixes the problem, but it does.
