'93 F150 Starting
Old Feb 12, 2011 | 02:44 PM
inlinescott's Avatar
inlinescott
Trailering
'93 F150 Starting
My truck will not turn over. I have replaced the solenoid with two different brands. First didn't do it and the last one worked a couple of times then stopped. I was able to get it to start once by moving the shifter (automatis trans.) so I think it may have something to do with that. Does anyone know where to find the switch that keeps the truck from starting when not in park or neutral? It starts fine when I bypass the solenoid.
Old Feb 12, 2011 | 03:54 PM
subford's Avatar
subford
On the drivers side of the transmission.
Old Feb 12, 2011 | 04:30 PM
inlinescott
Trailering
Thanks
Thanks for the quick reply. I will let you know if replacing the switch works.
Old Feb 12, 2011 | 05:38 PM
subford's Avatar
subford
Make sure your screws are tight.
Old Feb 12, 2011 | 05:58 PM
our 54 4d's Avatar
our 54 4d
If you look under the truck drivers side like the other guy said just fallow the shifter cable down some theirs an pitch nut you can adjust it first before replaceing the switch
synergy141
Jun 14, 2011 04:07 PM
56Jeff
1978 - 1996 Big Bronco
Oct 6, 2008 01:31 PM
79 bronc
Electrical Systems/Wiring
Oct 21, 2007 09:11 AM
