Dusted Turbo???
Old Feb 11, 2011 | 03:18 PM
cliffhanger_18's Avatar
cliffhanger_18
Trailering
Dusted Turbo???
This is about my 02 7.3l with 117000 on it. I just bought it and should have looked under the hood better. No runability problems but just took the air cleaner off and looked down the hole after reading some posts. The leading edges of the turbo blades are worn back about a 1/4 inch on every blade in a semi-circular pattern. I'm assuming this isn't good as I'm sure it's screwing my airflow up. Previous owner had a K&N on it that was so dirty I threw it out and got a new one. Are older turbos just like that, or am I looking at a turbo replacement down the road? Tried downloading photo but need to figure that out.
Old Feb 11, 2011 | 03:22 PM
snakedoc's Avatar
snakedoc
if ti looks like this than yes. see 2 page
http://www.motorcraftservice.com/vdi...argerGuide.pdf
Old Feb 11, 2011 | 03:26 PM
orng1's Avatar
orng1
The compresor blades should be very close to the housing. If not then you can look at either adding a wicked wheel, replacing the turbo or rebuilding it. Mine isn't that bad but it's showing wear. Still holds over 20psi easy though so I won't be replacing it anytime soon.
Old Feb 11, 2011 | 03:32 PM
cliffhanger_18
Trailering
Snakedoc, it looks just like the number 2 photo with foreign object damage
Old Feb 11, 2011 | 05:18 PM
snakedoc's Avatar
snakedoc
then it is time to replace it. like orng1 says.
Bill Kay
42
Feb 18, 2016 03:00 PM
RA31925
May 6, 2014 07:04 PM
ol-blu
Mar 23, 2014 08:48 PM
hivoltj
Bronco II
Aug 23, 2012 08:14 PM
