Sponsored by: Real Truck
u joints
Old Feb 11, 2011 | 01:43 PM
kyle brauner's Avatar
kyle brauner
u joints
I have a 2000 f-250 power stroke with 228,000 miles and I have never changed out the U joints. How do you know when the u joints go out or are going out?
The problems that I am having started about 3 months ago. I noticed that while sitting at a light in drive and my foot on the brake I would take off and for a split second there would be no movement then the truck would drive normal. I took the truck into a local diesel performance shop called Diesel Innovations and they suggested that it wasn't my transmission but they thought it could be my u joints. While I was there I purchased their 6 position chip and shortly after the truck started shifting irregular, meaning it was not sure when exactly to shift, and it sometimes shifted harder than other times.
Please give me your opinion before I take it back to shop. Do you think its my transmission? the chip? or the u joints?
The transmission was rebuild three years ago.
Old Feb 11, 2011 | 01:48 PM
ZeroTucker's Avatar
ZeroTucker
kyle, Are you in Bellingham? I noticed a shop the other day off Bakerview and am thinking it was called Diesel Innovations.
Old Feb 11, 2011 | 04:52 PM
mixerdrvr's Avatar
mixerdrvr
U joints usually start squeaking when they go out.
That being said I believe your shift problem is from the switch. Is it a shift on the fly switch? Can you change power setting while the engine is running? If so, this will cause problems with the transition.
Old Feb 11, 2011 | 05:07 PM
EXv10's Avatar
EXv10
Not the Ujoint but could easily be the tranny.
Old Feb 11, 2011 | 09:08 PM
DAVE67FD's Avatar
DAVE67FD
I don't think your u-joints are the issue either but with an automatic and shifting into gear (park-to-drive or park-to reverse) you may feel a clunking with a bad u-joint or even a clunking when starting from a dead stop or even during heavy braking. A bad u-joint may also exhibit a vibration under load and may go away during coast.
Grabbing the driveshaft with both hands with the tranny in neutral (truck not running, wheels blocked and e-brake on) shake it. Turn the shaft and shake at different positions. It should be solid with little to no play.
I can only assume the chip may not have setup your shift points properly or has compounded an existing problem. Your transmission should respond imediately with the pedal. By your comment it seemed the shop never looked at your tranny. Find another reputable shop. Have you had a fluid change or have checked the level in the tranny? lately
Old Feb 12, 2011 | 02:11 AM
EXv10's Avatar
EXv10
Normally a worn u-joint will clunk when you're on and off the gas, but they can also chirp like a bird when they dry out without clunking because they haven't gotten to that stage yet. If it chirps and clunks there is no need to even look under the vehicle, just get out your little wrenches and your wallet.
Old Feb 12, 2011 | 09:07 AM
ontariofarmer's Avatar
ontariofarmer
Daves got it....you will hear a clunk, or it might squeak. I'm sure it's got to do with the tranny
Old Feb 12, 2011 | 09:08 AM
redford's Avatar
redford
FTE Leadership Emeritus
U-joints do not slip. They either work or your drive shaft is laying in the road. There is nothing in between.
I would take your truck to an independent transmission shop (not a national chain, please) and have the transmission looked over. It might be something very simple and inexpensive at this point.
Old Feb 12, 2011 | 09:54 AM
kyle brauner
U joints
Well, see the thing is, it does not slip any more when I take off. For some reson that symptom has gone away. I'm worried about the way it has been shifting. I dont know why it shifts good sometimes and then other times it doesnt know when to shift or shifts tooo freaking hard.
Old Feb 12, 2011 | 10:30 AM
DAVE67FD's Avatar
DAVE67FD
With the chip, shift points may vary depending on how hard you are on and off the accelerator.
U-joints can exhibit squeaks, chirps, ticking etc.. Some people never recognize these noises as a problem until the vibration starts or they loose their shaft. You can also drop the shaft with no warning.
Old Feb 12, 2011 | 12:34 PM
EXv10's Avatar
EXv10
Because it is not in perfect condition or your controlling devices are malfunctioning. Time will tell with it but it would be a good idea to get a professional opinion before it gets worse.
Old Feb 12, 2011 | 12:42 PM
EXv10's Avatar
EXv10
In all my years of being a machanic and drag racing I have never seen a shaft drop with no warning unless you deliver a shocking blow to it like revving up and popping the clutch or dropping it into drive or reverse. They will squeek when dry and clunk when you loose the needles.
Old Feb 12, 2011 | 12:54 PM
DAVE67FD's Avatar
DAVE67FD
Exactly.
Also a good way to weed out the weak links. This also occurs with ones who up their HP numbers and don't pay any attention to the other items.
Being in drag racing im sure you have seen a few shafts (or u-joint pieces) left on the track.
Old Feb 12, 2011 | 01:11 PM
EXv10's Avatar
EXv10
Exactly.
I had Fairlane GT with a 390 and 4 speed that was all jacked up, 4.56 LS rear end, and big cheater slicks that I used to drag race at Fremont drag strip in Ca............lots of fun.
Old Feb 12, 2011 | 02:56 PM
nitrogen's Avatar
nitrogen
does the 7.3 have anything like the EBP sensor on the 6.0? if so that could cause erratic/hard shifting
drus136566
Mar 28, 2015 08:23 PM
TateF250
Sep 6, 2013 09:00 AM
slidingdelta
1983 - 2012 Ranger & B-Series
Jun 26, 2010 05:43 PM
transam525
Sep 4, 2003 10:00 PM
