Please help
Old Feb 10, 2011 | 10:54 PM
texanranger's Avatar
texanranger
Exclamation Please help
I have a 2006 f350 xl 5.4 v8. I turned on the map light on the passenger side and heard a pop. Now the power window, map lights, and radio don't work. The radio will eject a cd, light up with heAdlights, and display time when you push menu. Other than that that's it. I checked the mini fuses and 30 amp breaker and found nothing. What else can it be.
Old Feb 11, 2011 | 07:24 AM
Franklin2's Avatar
Franklin2
I only have 2005 diagrams, but if they are the same, I would check fuse #41 in the underdash fuse box. If that looks good, check all the fuses in the underhood fuse box.
