Idles too high
Old Mar 11, 2003 | 11:38 AM
89CrewCab's Avatar
89CrewCab
Idles too high
Hi all,
I had a shop do a valve job and replace both exhaust manifolds among other things. Well, it idled about 650 rpms before they did the work, and now it idles about 850-900 rpms and they say that is as far down as they can get it. The gas padel seems to have more resistance than before and and the check engine light comes on periodically --> resets itself when ignition is turned off.
They blame the high idle on a worn throttle body shaft. I think they installed something incorrectly, since it was fine before I took it in for the work. What do you guys think?
Thanks, 89CC
Old Mar 11, 2003 | 04:21 PM
chris93's Avatar
chris93
Idles too high
i think that if it was different as soon as you got it back,they did or didnt do something.i would go back ,and back and back.
Old Mar 11, 2003 | 04:28 PM
mantta's Avatar
mantta
Idles too high
Your idle air control valve may be sticking a bit. Take it apart and clean it up and it should cure it unless you have a vacuum leak somewhere else.
Old Mar 11, 2003 | 05:08 PM
89CrewCab's Avatar
89CrewCab
Exclamation Idles too high
Sorry, I failed to mention that it has been repalced!
Old Mar 11, 2003 | 06:17 PM
mantta's Avatar
mantta
Idles too high
Then, you could have a vacuum leak or maybe your base timing is too far advanced.
