Cleaning Electrical Terminals
Old Feb 10, 2011 | 08:51 PM
grinnergetter's Avatar
grinnergetter
Wondering if their are any cool tools or liquid solutions for cleaning things like light bulb terminals. I've tried small diameter gun brushes and pocket screwdrivers with minimal success. Dielectric grease is obvious for reassembly but we are just kinda making sure current flows through oxidation.
The female plugs on these trucks are pretty hard to get really clean.
Old Feb 10, 2011 | 10:23 PM
Carny's Avatar
Carny
I just noticed at autozone the other day that they had 3 different sprays for electrical connections. One was basically spray dielectric grease, I think the other two were cleaners, not sure really what the difference was between them.
You should try them and let us know if they work
Old Feb 10, 2011 | 10:25 PM
Carny's Avatar
Carny
I think these are the two I saw: Electrical Parts Cleaner | AutoZone.com
Old Feb 11, 2011 | 12:04 AM
fmc400's Avatar
fmc400
MSEE
Dielectric grease is a compound that keeps corrosion out of connectors and prevents them from seizing. It fills in the tiny gaps and cavities along the mating surfaces so that moisture, durt, salt, etc cannot. It is non-conductive (hence the term dielectric), so it can be spread across multiple terminals in the connector and not cause a short.
General-purpose electrical contact cleaner can be used to clean electrical terminals and can be found at parts stores, Radio Shack, etc.
Old Feb 11, 2011 | 05:48 AM
Poison Oil Racing's Avatar
Poison Oil Racing
I take some emery cloth and clean up the contact points then apply the dielectric grease.
Old Feb 11, 2011 | 10:32 AM
78 PEB's Avatar
78 PEB
I agree on the contact cleaner, but sometimes that just isnt enough. For the female connectors that are badly corroded, I have used what are referred to a jewlers files or needle files. I picked up a set years ago at one of the "cheapy" tool sale/auctions that travel around the country. Harbor freight may have them too. They work better than trying to scrape the crap out with a small screwdriver but still aren't ideal. You just have to be careful to not remove too much material so that it still fits tight when youre done.
Old Feb 11, 2011 | 01:34 PM
planehunter's Avatar
planehunter
Cleaning tight and small places is a real pain. I use several different methods. I buy a set of cheap emory boards for finger nails and trim them to size and shape. I also use contact cleaner sprays, but you have to be careful because some will soften plastic. I also use wooden dowel rods with a saw slit in one end that i insert some fine emory cloth and use like a hone. Again you have to be careful not to sand too long, and don't jam it in a socket because it might catch and tear it up. Time, patience and practice.
Old Feb 11, 2011 | 01:41 PM
grinnergetter
I like the emery board and doll rod idea. So much for the magic potion huh.
Thanks everyone.
Old Feb 11, 2011 | 02:08 PM
78 PEB's Avatar
78 PEB
Ive never tried it but just had a thought..........I wonder how a baking soda and water solution would work???? Works on battery terminals....................
