tail light refurb
Old Feb 10, 2011 | 01:11 PM
mattthegreat's Avatar
mattthegreat
tail light refurb
hey guys, well 2 things, my break lights aparently dont work, they worked 1 month ago (I know this becouse I had to back down a snow road for 300m, rideing the breaks in the dark), I recently replaced the break booster, so I checked the break switch that turns on when you press the breaks, it is atached and atached corectly. so the next thing would be a fuse, where is the fuse box and whitch fuse is for the breaks? I think I should start there and then check bolth bulbs, then the wireing.
secondly, I keep seeing these comershals for plastic head light lens restoration polish/buff, dose that stuff work on colored lenses or only clear lenses? mine are just realy fogy (found that out when I had to use a flash light to back down the above mentioned road )
thanks guys.
1985 f150, 4spd no overdrive, reg box, reg cab.
Old Feb 10, 2011 | 02:50 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The Fuse Panel is located under the dash hooked to the firewall.
The fuse panel should have a cover on it with the fuse panel diagram on it.
Here is also a fuse panel diagram attached to the power distribution wiring diagram.
http://i447.photobucket.com/albums/q...scan0002-4.jpg
As for taillamp restoration, yes that headlight restoration stuff will work on the taillights as well. You can also use jeweler's rouge with a buffing tool to polish the oxidation off headlamps and taillights.
Old Feb 10, 2011 | 08:28 PM
Duct Tape Racing's Avatar
Duct Tape Racing
you gotta scrub the hell out of them though if theyre bad
Old Feb 11, 2011 | 11:59 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Polishing the outside will help, but if they have a bunch of crud inside, they'll need washed out well. It can be tricky to clean the insides, since there's very little room to get anything in there to help break stuff loose.
Old Feb 11, 2011 | 12:08 PM
mattthegreat
thanks guys, ya it was a blown fuse, replaced it and they work great now.
going to see if I can polish them on monday, weekend is completly full unfortunatly.
