weird 4x4 question
Old Feb 9, 2011 | 07:22 PM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
weird 4x4 question
Need help please..I had to put my truck in 4 wheel drive "high" because the roads where bad with snow...I got home parked my truck leaving it in 4wheel drive and when I started it again, the dash said it was in 4x4 "low" when it was still in "high" and now it seems to be stuck in 4wheel low...can't even get into 2 wheel drive...any help??
Thanks in advance.
Old Feb 9, 2011 | 07:28 PM
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
Tell me more specifics about your truck. Year? ESOF?
Old Feb 9, 2011 | 07:34 PM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
'04 6.0 f-350...ESOF??? not sure what that is?
Old Feb 9, 2011 | 07:37 PM
Jakebrake's Avatar
Jakebrake
Do you turn a **** on the dash to engage/disengage 4 wheel drive, or do you have a lever on the transmission hump?
Old Feb 9, 2011 | 07:39 PM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
**** on the dash
Old Feb 9, 2011 | 07:47 PM
Jakebrake's Avatar
Jakebrake
With the engine running...do the following. Place foot firmly on the brake pedal and apply pressure and hold. Shift transmission into neutral (auto trans?) and then turn the **** to 4 high. Wait a short while and the display in the instrument cluster should indicate 4 high. Then repeat the process and shift to 2 high if you want. That should work...if it does not then try backing the vehicle (or move forward) and try again. Important to have foot on the brake when going into or out of low range.
Old Feb 9, 2011 | 07:49 PM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
I will try that...thanks bro!!
Will let you know either way the results.
Old Feb 9, 2011 | 07:54 PM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
That did it!!
Your a lifesaver!! I owe you. Thanks Jake.
