ficm power wire ?
Old Feb 9, 2011 | 04:27 PM
steelkiwi75's Avatar
steelkiwi75
ficm power wire ?
trying to remove my ficm. is there a certain way to get the connectors loose on bottom? i pushed in the first set of clips and pulled down a little bit, just enough that i could see the wires inside. is this the right spot to disconnect? should i just see wires? if so how do you reach is there to push the clips in on the other two? thanks dennis
Old Feb 9, 2011 | 05:03 PM
davidkstyler's Avatar
davidkstyler
IIRC there are three plugs that go in underneath the FICM, I think there is a tab on the side of each plug that will release the plug.
From Mark's Tech Folder post http://www.fordtechservice.dealercon...FICM_Guide.pdf
Old Feb 9, 2011 | 05:29 PM
npccpartsman's Avatar
npccpartsman
Page 9 picture 13 of the PDF shows the harness and plugs. You have to pinch/squeeze the tabs located on the driver and passenger sides of the plugs and pull down. They can be fairly stubborn to get out sometimes. You can just see one (there are two) on each plug in the picture that I referenced.
Old Feb 9, 2011 | 05:41 PM
steelkiwi75
i think that i am trying to take them off at the wrong place on the connector. from the looks at those pics, i should see no wires at the disconnect spot. thanks
Old Feb 9, 2011 | 05:44 PM
npccpartsman
I think that's a common "mistake". I did it myself the first time or two.
