1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2006 f350 carrier bearing vibration
Old 02-09-2011, 02:33 PM
cwocg's Avatar
cwocg
cwocg is offline
I installed a 6" fabtech lift on my f350 superduty crew cab. The problem is I have tried for 2 weeks to get the carrier bearing shimmed right with no luck, I have tried measuring the angle of the front and back drive shaft to ensure the match. I have gone up and done in shim size. I also purchased the superlift spacer that is meant for a 6 " lift. no luck with that. I have heard a 1/4" per inch of lift and an 1/8" per inch. but no luck there either. Any suggestions or does anyone have the size shim that worked for them?
Old 02-09-2011, 10:52 PM
DAVE67FD's Avatar
DAVE67FD
DAVE67FD is offline
I believe you should be about 1/4" per 1" of lift. If you purchased a 6" lift determine the "actual" amount of rear lift you installed. A 1-1 1/4" spacer should put you close. There is no exact specification here as too many variables are involved.
You want to check your rear axle pinion angle with the transfer case output pinion, not the driveshaft. This should be done with a relatively acurate analog or digital protractor.
I assume your complaint is a vibration issue?
Has the shaft been removed from the vehicle? If removed and not returned in it's orig position it maybe out of phase causing vibration. Have you confirmed all your joints are ok, or were any replaced ? It also may require balancing.
choptop49ford
12-03-2013 10:55 AM
newbie2006
10-28-2013 03:53 PM
F250Snowman
6.4L Power Stroke Diesel
04-11-2012 06:40 PM
rangermike
01-20-2011 08:40 AM
Ranger 620
11-09-2010 05:28 PM
Quick Reply: 2006 f350 carrier bearing vibration
