Sponsored by: Auxito
snowplow
Old Mar 11, 2003 | 06:18 AM
theboogers's Avatar
theboogers
snowplow
want to install a meyer poly plow on my 1997 f150, 4x4 , 4.6. what should i do to the front suspension or other areas to help handle this install? thanks
Old Mar 11, 2003 | 07:16 PM
Racerguy's Avatar
Racerguy
snowplow
How heavy is the plow?
You may want to add airbags or possibly just crank up the torsion bars a bit to compensate for the extra weight.
Old Mar 11, 2003 | 07:46 PM
theboogers's Avatar
theboogers
snowplow
plow and accessories listed at 600 libs. this sound heavy for a poly pllow, so i am not sure. thanks.
Old Mar 11, 2003 | 07:55 PM
theboogers's Avatar
theboogers
snowplow
600 lbs must be just shipping rate for everything. i will have to check out the plow in person. thanks
Old Mar 12, 2003 | 04:46 PM
TEEJAY's Avatar
TEEJAY
snowplow
I have a 97 F-250LD that I run a Western Unimount (7.5ft). I cranked up the torsion bars and installed a tranny cooler. No major problems yet. I think the fact that the entire unimount assembly comes off helps alot, because I can feel the front end difference with the plow and try to get it off as soon as I am done using it.
Good Luck
