Wheels?
Old Feb 8, 2011 | 07:57 PM
Hitokori's Avatar
Hitokori
Wheels?
i recently put my factory steel wheels back on my truck
it has a few places from rocks that have chips in the paint and rust
i really dont want to take my tires off to have them sand blasted
so my questions are
1) how should i strip the paint (what should i use)
2) what paint and primer
3) what paint would work best for re-pin striping the beauty rings
that is not my wheel but its what mine look like
Old Feb 8, 2011 | 10:31 PM
chop block's Avatar
chop block
i wet sanded my rims sprayed them with dupli color high performance wheel coating from auto zone, oriley , napa etc then just sprayed them with the color and cleared um they came out really nice hope that helps out a lil bit
Old Feb 11, 2011 | 09:39 PM
Hitokori's Avatar
Hitokori
Thanks hasn't anyone else paints wheels here or maybe have some general painting advice
Old Feb 11, 2011 | 11:39 PM
Chaosracing's Avatar
Chaosracing
When I painted rims at my neighbors shop with the tires on here is what I did. 1st mark location of wheel weights on tires. Remove the weights. I used a small handheld sand blasting rig (kinda looked like a garden sprayer) and blasted rust spots. Feather sanded the rest of the rim. I used a piece of sheet metal about 3" wide to form a loop around the rim ontop of the tire. This masked off the tire real easy. Clean rim with a wax/grease remover (Like PPG 320) The used good acrylic primer. Then we just spray bombed them. Reinstall weights after paint dries. As for the trim ring, I just used some straight enamel (or lightly thinned it) and used an artist brush to apply the paint.
Old Feb 13, 2011 | 10:28 PM
hojolabo's Avatar
hojolabo
Sandblast, prime, paint color of choice and just have somebody spin the wheel and a steady hand to stripe.
Sounds easy enough doesn't it.
BIGskinny
24
Jun 2, 2011 03:09 PM
bigbubba87
Mar 12, 2011 07:04 PM
mvedepo
6.7L Power Stroke Diesel
Oct 4, 2010 09:39 PM
F250FarmBoy
Paint & Bodywork
May 16, 2006 08:06 PM
Customz
Paint & Bodywork
Sep 30, 2005 09:54 AM
