I have a 1999 f-350 2wd dually. I need the part numbers for the wheel bearings and races. I have one on its way out on the drivers side. It is starting to get a little noisy. I want to replace it before it gets to bad. I know it has an inner and outer bearing but the parts store told me to bring in the old one and they would match it. there system did not show if it was inner or outer and they list like 30 different bearings for the F-350.
Thanks
NATIONAL Part # 15101 Taper Bearing Cone; Bore=1", Length=0.8125", Radius=0.031" Front Wheel; RWD; Outer
NATIONAL Part # LM102949 Bore=1.7812", Length=0.78", Radius=0.14" Front Wheel RWD Inner
Races:
NATIONAL Part # 15245 Outer Diameter=2.441", Length=0.5625", Radius=0.046"
NATIONAL Part # LM102910 Outer Diameter=2.891", Length=0.62", Radius=0.031"
Front Wheel; RWD; Inner
These are from Rockauto.com so I cannot guarantee if they are valid
Thank you. I was able to find them and will be picking them up in the morning. Will be packing the bearings the old fashioned way so it will take a little time.
