My wipers quit???
Old Feb 7, 2011 | 06:09 PM
roostercrows's Avatar
roostercrows
My wipers quit???
Hey guys, I seem to be having a stretch of problems with my truck. First all of my brakes, then my starter, then my alt. and now my wipers have quit!
Not only that, the washer pump has quit too, both without any warning and at the exact same time?
Does anyone have any idea as to why or how this could happen?
Thanks guys.
Old Feb 7, 2011 | 06:16 PM
snakedoc's Avatar
snakedoc
have you looked at the fuses, my brothers truck stopped and it was the switch on the column, i just sprayed it with electrical cleaner.
Old Feb 7, 2011 | 07:02 PM
roostercrows
thanks Matt, I did check fuse 33 and 106 the wiper fuses but both were fine.
How do you mean it was the switch on the column?
Old Feb 7, 2011 | 07:55 PM
snakedoc's Avatar
snakedoc
the one that controls the wipers, when he would twist his noting worked so i sprayed all over it and in it and it started working.
Old Feb 7, 2011 | 07:59 PM
roostercrows
hmmm, how did you spray in it? In the end by the column? Did his spray stop working at the same time?
Old Feb 7, 2011 | 08:10 PM
snakedoc's Avatar
snakedoc
i dont know about the spray, i just sprayed it around the end where it twisted, could not get the end off.
Old Feb 7, 2011 | 08:13 PM
roostercrows
Thanks Matt, I'll try it tomorrow.
Old Feb 7, 2011 | 10:30 PM
spunks00's Avatar
spunks00
My wipers quite due to my GEM getting wet from a leaking windsheild. Thats another thing to check. I was able to get them to work after being dry for a day or so, but if it sat in the rain it they would not work. Also i had intermittant issues with :CC, speedo, abs, air bags, and some other stuff too.
