dana 44
Old Feb 7, 2011 | 10:00 AM
redhawk41's Avatar
redhawk41
dana 44
I have a 73 f150 and an 82 bronco the 73 has drum brakes can I take the disks off of the 82 and put them on the 73 from the knuckles out?
Old Feb 7, 2011 | 10:29 AM
rockpile's Avatar
rockpile
I dont know if you can swap em straight up. but my buddy says a d44 ia d44, so you'll probably have to swap knuckles. you could just take em a part and find out. it should be obvious before you have it all the way apart. goog luck!
1979 F-150 4x4, 400,35" boggers
1986 F-250 4x4, 460, 10,000lb warn winch.
Old Feb 7, 2011 | 10:46 AM
PA74F250's Avatar
PA74F250
This maybe a little off topic of your subject but...Is it possible to take a LP D44 w/ closed knuckles and turn it into the later LP D44 w/open knuckles and dics brakes. I was thinking about swapping the outers and axles, brakes etc since the gears need work on the one I have laying around. I just dont know if its possible.
Old Feb 7, 2011 | 10:50 AM
redhawk41's Avatar
redhawk41
Has anybody done it or tried it?
Old Feb 7, 2011 | 11:00 AM
PA74F250's Avatar
PA74F250
Is the one you have the '82 high pinion?
Old Feb 7, 2011 | 11:16 AM
redhawk41's Avatar
redhawk41
It has the factory ttb bronco front axle.
Old Feb 7, 2011 | 12:00 PM
c.l.nye's Avatar
c.l.nye
short awnser,no. the spindles have a different bolt pattern,the caliper brackets are diff. too. the only parts that are the "same" are the rotors. your best bet would be to find a 77-79 to get all your parts from.
Old Feb 7, 2011 | 12:02 PM
PA74F250's Avatar
PA74F250
Ohh yea I can see that being different.
