exhaust manifolds
Old Mar 10, 2003 | 07:55 PM
idealtrucks's Avatar
idealtrucks
exhaust manifolds
are the exhaust manifolds off of a 1970 and a 1976 360 the same??
Old Mar 10, 2003 | 08:48 PM
jbulson's Avatar
jbulson
exhaust manifolds
I believe so.
Old Mar 11, 2003 | 11:21 AM
chissler's Avatar
chissler
exhaust manifolds
As long as it is an FE in a truck they are the same from 1965 tru 1976. There are some different manifolds for cars, most of them will work if you have an exhaust shop build new pipes.
Old Mar 11, 2003 | 11:23 AM
William's Avatar
William
exhaust manifolds
All true! Use a truck manifold for the right side or you will need to nick the frame or bend it up a bit to clear. Looks cheezy if you do it that way.
Old Mar 12, 2003 | 12:59 PM
DJ Rosa's Avatar
DJ Rosa
exhaust manifolds
can a guy use factory exhaust manifolds and all new exhaust like flow techs and get good rumble and sound.I just re did top end and primarily want the truck to sound bad it wont be raced??
Old Mar 12, 2003 | 01:39 PM
William's Avatar
William
exhaust manifolds
Short answer is yes! I use 2 1/4 inch pipes dual to the muffler (Flowmaster dual in single out) and then 3 inch pipe out behind the R/R Tire. Drones a bit but sounds nice. I plan to add a crossover under the oil pan hoping the drone goes away. This system is quiet, but sounds serious, and I have friendly neighbors.
Old Mar 12, 2003 | 04:27 PM
chissler's Avatar
chissler
exhaust manifolds
Does anyone have any cast iron headers like they used on the old 406's and hipo 390's? There is some on ebay now and then, but they want like 400 bucks, does anyone offer aftermarket ones?
Old Mar 12, 2003 | 04:39 PM
Ratsmoker's Avatar
Ratsmoker
exhaust manifolds
Nope, if you want these manifolds you will either have to find them in a scrapyard which is near impossible or pay big bucks for them.
Old Mar 12, 2003 | 05:15 PM
jbulson's Avatar
jbulson
exhaust manifolds
I have stock logs and 2 1/2 inch true duals with 36 inch glass packs, It sounds bad *** to me.
Old Mar 12, 2003 | 06:35 PM
CACWBY's Avatar
CACWBY
exhaust manifolds
Carls Ford Parts has these - they are in Ohio
http://www.carlsfordparts.com/
