Cleaning Catalytic Converter?
Old Feb 6, 2011 | 10:52 PM
JordanL79's Avatar
JordanL79
Ok so I got a Ford f250 79 with a 400 6.6L engine in it. It has about 60k miles on it. I was wondering if I should get a new tall pipe for it because it might be choking my engine some what. If it is how much HP could it be hold up? Also I would like to some how clean my catalytic converter or even just take it off if that's not a crime. Also how much HP could the cat be holding?
Old Feb 6, 2011 | 11:00 PM
78 PEB's Avatar
78 PEB
Correct me if I'm wrong but I dont think a 79 F250 ever even had a cat..........unless maybe it was originally a California truck????????????
Old Feb 6, 2011 | 11:09 PM
83sd's Avatar
83sd
iirc the easiest way to tell if you need cats is , if the fuel gauge says "fuel " its not catalyst and if it says unleaded gasoline only its catalyst.
also , if you need to replace them, autozone sells universal cats for around $60
Old Feb 7, 2011 | 09:17 AM
Carny's Avatar
Carny
If the engine is stock I don't think new exhaust is gonna gain you much, if anything.
Old Feb 7, 2011 | 09:24 AM
highboy1975's Avatar
highboy1975
its more than the exhaust choking that engine. if you want to replace the cat, do that, but i know of no way to clean a cat out. call your local inspection station and what they do as far as emissions on your vehicle. call a few for that matter and find out if they say anything about cats.
Old Feb 7, 2011 | 10:59 AM
johnson2007's Avatar
johnson2007
Pull the exauhst off ur truck, take a screwdriver and knock out the insides of your cat. Put it back on and it will look like you have a cat but it won't be hindering your exhaust.
sittinguy
Aerostar
Dec 21, 2016 07:42 PM
spthomas
2004 - 2008 F150
Nov 24, 2015 12:45 AM
1990inline6
Oct 2, 2014 08:11 PM
CNC
Apr 9, 2010 06:45 AM
MAXedOut
Sep 25, 2009 09:08 PM
