broken FAQ - 5-speed transmission swaps
Old 02-06-2011, 07:52 PM
ctubutis's Avatar
ctubutis
ctubutis is online now
https://www.ford-trucks.com/forums/7...-pictures.html
First, my original shifter layout:
Old 08-23-2015, 01:48 AM
biglou96's Avatar
biglou96
biglou96 is offline
nice setup (: sorry to bother but you might be able to help me you see i have an 84 shortbed witha 4.9 and i was wondering if you knew any good 5spds that will fit my truck i was told it has a 4spd for a 3/4 ton truck and it does feel pretty strong and slow paced
Old 01-19-2016, 11:26 PM
Shadow944795's Avatar
Shadow944795
Shadow944795 is offline
From what I know with the newer trucks. if you can source up a ZF-5 (Hard to find trans these days) Trans for a small block ford you will have a transmission that the 4.9L will not kill. But if all you really want is an overdrive to play around with and you aren't loaded to the max all the time a M5OD (More common trans and easy to source up) will in fact work well for you.
Old 09-08-2017, 02:03 PM
RenoHuskerDu's Avatar
RenoHuskerDu
RenoHuskerDu is offline
How about a 5spd upgrade for a 6.9 IDI? Mine has a 4sp in it. There are lots of 5sp trannies in the pick&pull I visited yesterday. But would any 5sp hold up to the diesel torque, bolt up to the clutch housing, match the input shaft in the clutch disk, etc?
Old 09-08-2017, 10:06 PM
ctubutis's Avatar
ctubutis
The 5-speeds offered in later years have a built-in bell housing, it's not just plug-n-play.
ctubutis
'80-'86 HOWTO's
11-12-2023 12:34 PM
fastman35
13
11-27-2016 09:24 PM
BruteFord
Oil & Lubrication
17
05-23-2016 09:54 AM
Quick Reply: broken FAQ - 5-speed transmission swaps
