Sponsored by: Real Truck
Rear diff flush
Old Feb 6, 2011 | 07:17 PM
ganzey's Avatar
ganzey
Rear diff flush
i looked and my truck calls for 75w140 in the rear. the cheapest i can find it is $18 a quart, and i need 4..but i also found that lucas oil stabilizer says you can use it in differentials, and its $25 a gallon. i use lucas in my oil and never knew it could be used in dif's. anyone do this?
Old Feb 6, 2011 | 08:28 PM
wulfman's Avatar
wulfman
Go to wallmart get there super tech brand 75w-140 synthetic 10.55 quart just put it in mine yesterday. If you have the limeted slip rear then you need a friction modifier 4oz, ford or pepboys has it .
Old Feb 6, 2011 | 09:47 PM
ganzey's Avatar
ganzey
is there anyone that has actually used it in theirs? just wondering because i dont want to drive all the way back to return this, then spend another $15 on gear lube.
thanks
Old Feb 7, 2011 | 06:59 AM
wulfman's Avatar
wulfman
Look wallmart doesn't whip this up in the back stock room it has to be made by one of the major oil manufactors. You are not paying for the labeling and advertising. Kind of like genarics . JMO
Old Feb 7, 2011 | 07:11 AM
PsycoJuana's Avatar
PsycoJuana
im bout to swap in some royal purple, as of the Lucas i'd email them to double check.
Let us know
Old Feb 7, 2011 | 09:46 PM
ganzey's Avatar
ganzey
i know that. i used the supertech whatever in my front dif, but it was like $4 a quart. im just tryin to save a buck, considering i need a rear diff cover as well
well whatever. im just going to get the walmart stuff because this lucas is thicker that molasses in the middle of january(no joke, it would take hours to pump a gallon into my diff) ill just return it i guess.
Anyone know where to get a cheap diff cover? its a ford 10.5inch.
Old Feb 7, 2011 | 10:08 PM
dchamberlain's Avatar
dchamberlain
Lucas oil stabilizer is an oil additive. It's not meant to replace the oil.
Old Feb 7, 2011 | 10:50 PM
rickf92592's Avatar
rickf92592
Correct, it's meant to increase viscosity.
Lucas was kind enough to build us a straight 250W synthetic for the Trophy Truck, now that's thick! Takes a long time to warm the third member.
Old Feb 7, 2011 | 10:51 PM
ganzey's Avatar
ganzey
well, this is the cheapest i can find the cover. it is chrome, but i figured i can just sandblast it and paint it black. anyone opposed to this? are the ones on ebay super thin?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Feb 7, 2011 | 11:43 PM
rickf92592's Avatar
rickf92592
Try the 2008+ alum cover.
Old Feb 8, 2011 | 10:45 AM
bpounds's Avatar
bpounds
www.partsguyed.com
Old Feb 8, 2011 | 03:15 PM
ganzey's Avatar
ganzey
thanks but i didnt know autozone carried them. $37 later...it should be here tomorow
Old Feb 8, 2011 | 04:19 PM
bpounds's Avatar
bpounds
If you get an aluminum with fins for that price, we would all like to know about it. So let us know how you like it. Maybe share the part number.
Old Feb 8, 2011 | 05:32 PM
wulfman's Avatar
wulfman
Hell yea i want one to let us know
Old Feb 8, 2011 | 05:33 PM
rickf92592's Avatar
rickf92592
I have a feeling it's steel.
