HEATER PLUG WIRING
Old Feb 6, 2011 | 01:47 PM
SILVER STROKE's Avatar
SILVER STROKE
HEATER PLUG WIRING
my plug for the engine block heater broke off and I replaced it with a another 3 prong end. I just figured the Green wire was for the ground or the top prong on the plug. Other 2 wires were black. Noticed on the black wires that the copper was discolored so I cut back a few inches before replacing the plug. Question is does the green go to the top prong?? Should've asked here before I replaced couldn't find any diagrams anywhere else.
Old Feb 6, 2011 | 01:53 PM
clintbonnie's Avatar
clintbonnie
Yep, the green is always ground or your top prong. You can also check the heating element without being plugged in.. it should be around 15 ohms of resistance..
Old Feb 7, 2011 | 02:57 PM
SILVER STROKE
THANK YOU just started doubting myself I guess.
