Sponsored by: Real Truck
is this a major problem?
Old Feb 5, 2011 | 02:55 PM
878ranger878's Avatar
878ranger878
hey going to buy this 2001 f250 if you guys say this isnt a problem. See in the picture how the bed is tilted right below the back window? is that a bad sign? it has a few dents on the rear fender and rear bumper would that of done it?
Thanks alot guys.
Old Feb 5, 2011 | 05:55 PM
m350's Avatar
m350
Looks like it could just be the Tounau (spelling) cover, not sitting right,,,A friend of mine has one,,,the wind got under it,,,lifted it up,,dented the back of the cab and was, out of wack,,,,Just had to lift up high and reset it on the Hinges.
Old Feb 5, 2011 | 06:32 PM
akorcovelos's Avatar
akorcovelos
yeah, if its just the cover not a problem, if it is the whole bed tilted like that run.
Old Feb 5, 2011 | 08:33 PM
acf6's Avatar
acf6
Do you have any other pics from the back? itd be easier to tell if we could see the whole back end
Old Feb 5, 2011 | 10:41 PM
Furian's Avatar
Furian
You Keep What You Kill
It's probably the rear leaf springs... one is shorter than the other. My 2005 F350 had a similar issue and was fixed by a TSB. The dealership installed a 1/2" shim in the left rear leaf spring and now it fine.
Old Feb 6, 2011 | 10:01 AM
BareBones's Avatar
BareBones
If its the cover, no problem. If its just the bed, no problem. But the bed sits directly on the frame, and that could be a problem!
Old Feb 6, 2011 | 11:09 AM
Snowseeker's Avatar
Snowseeker
Is the truck sitting on a level flat surface?
Old Feb 6, 2011 | 11:44 AM
878ranger878
Hey thanks alot for the input guys! The truck is Not on level ground but even on level ground it still looks like that. In the pictures below look at how the lines of the truck run straight with one another. I think i'm convinced its the tonneou (SP!)
Also i'm going to get those big dents taken care of... i know it looks trashy at the moment.
Old Feb 6, 2011 | 11:51 AM
Kajtek1's Avatar
Kajtek1
Lift the top and see how the actual bed lines with the window?
If you don't feel qualified to diagnose the issue -spending couple hundreds for proffesional inspection might be vise investment.
Old Feb 6, 2011 | 03:23 PM
akorcovelos
if the body line match up I would assume it's just the bed cover.
Old Feb 6, 2011 | 03:41 PM
scraprat's Avatar
scraprat
Top Answer: 5
x2, Put it on level ground and measure from the ground to the bottom of the bed.
