Got a leak Scared!!
Old Feb 5, 2011 | 01:43 PM
tankd72's Avatar
tankd72
Exclamation Got a leak Scared!!
Well I went outside this morning and noticed fluid on the ground. I crawled under and looks to be coolant coming from somewhere above the starter on the passenger side. Popped the hood noticed de-gas bottle was low not empty but low. Filled back up truck starts runs fine ran to grocery store ran fine. Parked it in new spot on drive way and after 5min I see on the ground more fluid. Checked oil looks fine no water in it. The truck is 04 6.0 with 78k no mods other than cat back exhaust. I hope it isnt a head gasket! Any ideas on what it may be? The real bad thing is after being laid off and unemployed for 1-1/2 years I finally am back to work but broke as broke can be trying to save our home.
Old Feb 5, 2011 | 02:00 PM
cheezit's Avatar
cheezit
its the oil cooler to egr cooler adapter hose. short littie orange hose (new part is blue) it runs about $38.00 or so for the part.
Old Feb 5, 2011 | 02:09 PM
tankd72's Avatar
tankd72
Thank you Cheezit I pray that is it. Is the part a dealer only part? How much of a pain is it to change out?
Old Feb 5, 2011 | 02:11 PM
cheezit's Avatar
cheezit
its not bad to change out.
remove the hotside cac tube.
remove the 2 torx bolts fromt he adapter
remove adapter nad hose in one assembley.
I have no idea what is available in the aftermarket sorry, Im a dealer guy so I get my parts from the dealer.
Old Feb 5, 2011 | 03:14 PM
tankd72's Avatar
tankd72
ok checked that and after looking closely at the fluid it isnt coolant it's clear oily fluid. gonig to let it run of awhile to see if I can see what it may be.
Old Feb 5, 2011 | 05:09 PM
cheezit's Avatar
cheezit
clear oily fluid. check for a fuel leak at the filter housing. either lid or regulator seal leaking
Old Feb 5, 2011 | 08:08 PM
Headviking's Avatar
Headviking
Tast the fluid. You will be able to know right away. Just place your finger on the tip of your tong.
Old Feb 5, 2011 | 11:55 PM
m-chan68's Avatar
m-chan68
John, you have a wacky way of identifying automotive fluids don't you?
Old Feb 6, 2011 | 05:59 AM
tankd72's Avatar
tankd72
I isnt fuel I didnt taste it. The strange thing is after talking to my wife she said the other morning taking the kids to school she noticed a whine like low powersteering fluid. I checked and it is not registering on the stick in the cap? I got back under the truck to look and the areas around pump and steering box are dry no leaks on driver side? Rolled over to side that leak is showing up and noticed the clear fluid is collected ready to drip off trans lines that run from cooler to trans just so happens the lowest point of the lines are directly below starter. I checked trans fluid and it is full? Sunday I am going to run to Autozone get powersteering fluid drive around for a while come home park sit in a chair with beer outside watch and wait to see if it leaks again to try and catch where it is coming from I guess. Glad I put TV in garage for Superbowl :-)
Old Feb 6, 2011 | 10:08 AM
moebdick's Avatar
moebdick
I once had a leak at one of the hoses to external transmission filter. Apparently the factory clamp got weak and lost the ability to keep the hose tight. Of course, if it's trans fluid the fluid should be red not clear, but then again so should your PS fluid (unless its really dirty and brown). Maybe check to see what color it is by wiping it off on a white paper towel.
Old Feb 6, 2011 | 10:25 AM
Maxium4x4's Avatar
Maxium4x4
If the fluid is clear, air conditioning, front shock, or brake fluid. Just throwing some suggestions out. Windshield wiper fluid work?
Old Feb 6, 2011 | 04:05 PM
04F-250mark's Avatar
04F-250mark
I had the same thing happen turned out the factory steering stab. was shot.
Old Feb 6, 2011 | 06:50 PM
rdunagan's Avatar
rdunagan
sure its not just a/c drippin down? could be a thought
Old Feb 7, 2011 | 08:56 AM
tankd72's Avatar
tankd72
It is clear in color,not water because it takes days to evaporate and water beads up on the groud where it puddled. Drove it around sunday got to operating temp came home parked and watched for leak and it never leaked. Will keep trying to locate it if it shows up again
kr98664
Feb 15, 2022 01:24 PM
armyveyf250
Jul 26, 2016 01:51 PM
kegger66
15
May 30, 2016 06:44 PM
hillcountryflt
Feb 16, 2016 02:57 PM
Fred_89BII
Bronco II
Sep 8, 1999 08:18 PM
