What kind of truck is this for?
Those look like they may be gas sending units on the tanks, the extra 2 wires being for the fuel pump. Why are you trying to replace the chassis harness? We need more details to help you out.
That is definatly a gasser sender. Same as what is in my tank now. Don't try to use that intank pump to run your truck. It is a high pressure unit for EFI and will over prerssure your ip. I use it but have a bypass regulator in my fuel line.
don't pay attention to the number of wires on the sender...I have a couple of senders out of diesel trucks that have the four wires but the two wires for the gas fuel pumps aren't hooked up on the tank side.
I pulled one of the units, and its defenitly a diesel unit. Only one (yellow) wire hooked up.
Now, on that last picture, there is a harness with two relays, the harness out of the junk truck doesnt have a plug for it. It comes out of the fuse box under the hood. Im guessing it has something to do with the 4wd?
I do have another harness that i pieced toghether that has the plug. The new harness i have is out of a 2wd truck.
