Steering gearbox debate... Again...
So after driving the work trucks all winter and our new to us 01 superduty I have found that even though I adjusted the box in my X and the steering feels tight at the steering wheel the box still allows wheel/tire movement which causes wander. I wasn't very aware of it before because I always had some trailer in tow and just thought the trailer was pushing the x around some. After pulling the X out of storage, having a fresh feel of it and driving it alone I instantly realized the box has slop.
So here comes the debate of boxes. I know it has been talked about, there has been group buys, and some problems and whatnot with the red heads.
I would like to have a fresh up to date discussion about redhead and other parts store boxes.
From what I remember reading many are happy with their redheads but a few had problems. What the ratio is I don't know but out of the amount bought I would only expect to maybe see one person have a problem with a box. But it seems there were more than that?
At the same time it seems more than a few people have gotten box store boxes and I can't recall any of these people complaining about a bad box?
I know redhead claims to replace a bushing with a bearing, but I also seem to remember that the newer 01+ boxes have bearings stock from the factory anyhow? If that is the case and the rest of the box is just a simple rebuild are they worth around double the cost of a box store box?
I would like to hear everyones experience with box store boxes.
What do oem ford rebuilt boxes cost and are they worth it?
The one benefit I can think of is if there is a problem with the box store box they are only two blocks away which would make an exchange easier than if there were a problem with a redhead.
You guys know how I am, I like to make very educated parts decisions.
I have had my Redhead box in for a couple of weeks. So far so good, nice and tight, responsive steering. No complaints from me, handles quite a bit better than with the stock box. I can't say the OEM ones are bad, I mean mine had 230k+ miles on it...Shop was going to charge near 500 bucks for OEM, came out about 100 bucks more for the Redhead, since I purchased. I can tell you they were impressed with the box and wanted to know where I got it..
-Art
-Art
I bought a Redhead box after doing all the other crap....
It took 3/4 of the wander out....way better but not all.
I called Joel up there and had a good discussion. He said he wanted me to double check the ball joints for being sticky.
But I had just had am alignment done and they said everything was good and no slop. Joel said he'd be happy to send out another box if all else was good. But he wanted me to double check.
I didn't have an alignment rack to check the ball joints with the weight on them so I just said the hell with it and drilled them and hammered in zerks and greased them up.
And......kapow the last 25% is all but gone. It's so much better than when I first got it.
Obviously the joints where sticky but there was still a ton of slop in the original box.
If I were you I would see if you lower joints are greasable and if not make them that way....it took my 10 minutes. Because if yours only wanders a little...that may be why.
I only have about 3k miles on the new box but am happy at this point and the customer service "was on point"
All 4 of my ball joints are replaced and have zerks in them. I just greased them up about a week ago as well while doing the oil change.
Yes it was and I followed it from start to finish as well as replied a few times in it.
I started this thread to get a fresh update hopefully of people that do have redheads and how they are holding up.
I am also very interested in what kind of luck people that got box store boxes are having.
Thought you might, The pitman shaft seal blew out after 50 miles and was pumping out fluid at a alarming rate. The box came from Rock auto, They were pretty good about returning it and I put the money toward a Redhead. I cant say that I really noticed much difference in the two as they both seamed to tighten up the play I had..
