No clicky no nothing. Sounds like possibly your starter is bad. How did you jump your solenoid. Screw driver from the S terminal to Battery? Make sure your connections are tight . battery, solenoid starter, ground . Where is your battery ground to the block or body? Do you have headlights, anything?
After many days of sleepness nights, and many headaches.
I pulled on the lead wire into the solenoid, and it pulled out in my hand. So I cleaned her up, and re-crimped in a vise. So my truck is road worthy again. :-)
