>Does anyone have the torque spec for the nut that holds the
>pinion yoke on for a 9" differential Thanks, Mike
My Ford 1987 Light Truck Specs book says for the 8.8- and 9.0-inch rear end (conventional and traction lock) the minimum torque required to tighten the pinion flange nut to obtain correct pininon bearing preload is 160 foot pounds. A footnote says that if the preload exceeds spec before this torque is obtained to install a new spacer. As for the preload, it says of the 9.0-inch rear end that pinion bearing preload should be 8-14 ft lb for the original, and 16-29 for new.
INLINE SIX POWER! '95 F150 XL
300 Cubic Inches of Low RPM Truck Torque! And twin-I-beams too!
"Drive a stick young man! There'll be time for automatics when you're old and unable."
Thanks, Tallpaul, I've got it back together, But I know I don't have it tight enough. I didn't want to get it too tight. I had the procedure, but no specs. Mike
I kinda figured you would have. Sorry about the delay. Hey, I once replaced the pinion seal on my '77 F150 and didn't even know there was a torque spec. I just cranked on it till I thought it was good and it ran fine.
